I recently bought the Rutland lift and motor and fitted it in a homemade table based (strongly) on the Norm Abram deluxe design (pics below). I think the Rutland normally goes for £400 but got mine for £300. Power is either 2.4kw or 1.8kw depending on which bit of the (largely incomprehensible) manual you read! Plenty for me. I had been looking on eBay for a secondhand standard router of similar power to build into a table but they seemed to be going for silly money so it wasn’t a huge jump in cost to get the Rutland, with the added benefit of the plate and lift included.
Most of the wood for mine came from offcuts so all in it cost me c.£500. For what I’ve now got that is a pretty sound investment for me. It also extracts really well when hooked up to my 4” workshop extraction system.
I have not used it extensively yet but so far I’m pretty impressed - subject to the niggles below. Motor is fairly quiet and smooth with a soft start up. Plate seems rock solid and flat.
The only niggle so far is the way the crank attaches to the lift. If the bolts holding the mech together are tightened the gears mesh so firmly that the mechanism locks up. Those bolts need to be slackened a long way to get the gears to work. The result is a sloppy fit which rattles a bit when in use. It all works fine and shouldn’t cause long term issues hopefully but it strikes me as a bit of a bodged design which lets the rest of the motor/lift assembly down.
the other niggle is the crank handle is fixed in position with a couple of grub screws. If the required height of the cutter is achieved by a crank position anywhere between 10 and 2 o’clock then the handle is above the level of the table which would require the handle to be removed to feed larger pieces. Again, a pretty basic design failure which could have easily been anticipated and rectified with minimal thought and effort.
I raised these issues with Rutland and got a pretty unsatisfactory response - along the lines of that’s just the way it is.
Clearly this is a much cheaper and less refined piece of kit than the Jessem or equivalent, so on that basis I’m happy to live with the niggles.
