PerranOak
Not sure I get that ... bit thick, I am.
Drill a hole but how will the screw stay put in a smooth metal hole?
Most routers have tapped holes on the base, used to hold some jigs in place or to hold the router in a table. The screws go though the plate in the table into the thread in the router, no need to put a thread into the plate. Not that is that hard to do using a tap, which cuts the thread into a hole.PerranOak":391dnlj7 said:... but don't you have to put a thread into the hole? How do you do that?
Steve Maskery":105mjv4e said:My first RT was a piece of plywood with a hinged leg at one end and a cleat at the other, clamped in my workmate. The fence was MDF and two G-clamps. I did a lot of stuff on that.
contadino":1p21gihb said:The thing that's confusing me about a router table is setting the depth. I have a Bosch POF 1200 AE which doesn't have a screw-type depth adjustment thing. I've looked at things like the Router Raizer, but it's not compatible with my router. I've read about sticking a car jack under the router and adjusting it like that, but it seems a little dangerous to me.
Not having the money to shell out for a new router, what are the options?
Thanks.
andysubaru30":5osg4ttl said:I see Rutlands are doing an offer on a router table for £89 i think. Can anyone give me advice on it and any user reviews would be helpful, Thanks
andysubaru30":31klryg4 said:I see Rutlands are doing an offer on a router table for £89 i think. Can anyone give me advice on it and any user reviews would be helpful, Thanks
Creampuff":1fxymnar said:andysubaru30":1fxymnar said:I see Rutlands are doing an offer on a router table for £89 i think. Can anyone give me advice on it and any user reviews would be helpful, Thanks
I bought one of those a few months ago.
All in all not a bad table for that price, easy to put together, although you may need to drill a couple of holes in the insert plate to accommodate you particular router.
The table top is heavy and flat and will take the weight of a nice chunky router.
One thing I would suggest is not placing the 2pcs of adhesive measuring tape where it says in the manual (and in the picture) as all this will do is catch on the work piece running along the table.
The fence is cheap, but does all that you'll need it to do, it can stick and become hard to move, this is because the bolt that fit in the T track are not a great fit.
The main frame looks very flimsy, but this can be easily remedied by boxing it in with MDF with a door on the front, and a shelf to stick all your bits on.
All in all for a first router table, its done me proud...
Now I just need to make a bigger one that will take the 17" incra positioner I just bought... :shock:
Regards
Andy
Creampuff":qtpbgidh said:It is indeed a good table and a nice size for that price.
I'm sure you'll have many happy hours with it :wink:
As for the collet extension, I believe this one has had some good reviews
http://www.rutlands.co.uk/cgi-bin/psPro ... i/XTENSION
Regards
Andy
