Chippygeoff
Before I go and part with my hard earned cash I need some advice. I need to buy a small router table and a router. It has to be small as space is limited. The main criteria is that I need to be able to adjust the cutter height without bending under a table as I am disabled and this would not be impossible. I have had a good look at whats available and at the top of my list is the Trend CRT Mk3 router table with the Trend T11 router.
Its main use will be to put a moulded edge on plaques and to make small plinths in 18mm hardwoods. I like the idea that the cutter can be raised or lowered with a socket. I will be doing end grain work as well but have heard that the mitre fence is a sloppy fit and if this is the case I am worried I wont get a true 90 degree finish to a square base. I am sure there are some of you out there with this combination and if so could you give me your opinion please. Many thanks.
