RogerS
I wanted to run a Roman Ogee along the top of a lot of skirting board and decided that a router table would do the job nicely. I purchased a 'special' Ryobi (see brief review in a separate post) and set it all up. Being new to this lark I'd read up as much as I thought I needed to, knew all about feeding against the direction of rotation, knew all about machining off wood gradually etc.....or so I thought.
I adjusted the fence to take off a small amount of material and fed in a sample piece of wood. The brand new TCT cutter cut beautifully although somewhat fiercely but I still felt really chuffed. My first router table!! There was a nagging doubt at the back of my mind, however, as I felt that the router wanted to pull the wood from out of my hand. The experts among you will know where this email is going
I re-adjusted the fence to take a bit more off and fed the wood through again. Cut OK but still that nagging doubt as the tugging sensation increased.
I paused for a while and reassured myself about the direction of the cutter rotation and came to the conclusion that I was feeding the wood in the wrong way. I tried feeding in the wood from the opposite end. The router cut OK-ish and of course it didn't try to pull it out of my hand.
However, the fact that the outfeed was adjustable meant that if I was to feed it in from the opposite way (ie against the direction of rotation) then the outfeed was the infeed and since the outfeed was adjustable it didn't really make any sense to me at all and I was starting to get really confused!
One possible conclusion that I came to was that the router was rotating the wrong way round. How naive could I get!!! I soon came to the conclusion that that likelihood just wasn't sensible and went back to feeding the wood in the direction that I originally used. I adjusted the fence to take off some more wood and fed the wood in.
In a flash, the wood was ripped out of my hands and fired into the wall at a phenomenal speed. I was well and truly shocked at the sheer violence of it all.
So I went and had a cup of coffee and went back to square one as clearly something was not right. The answer, of course, was simple but not obvious to me. I was feeding the wood in on the wrong side of the router bit. The orientation should be wood, bit, fence and not what I was doing which was bit, wood, fence. The reason why I had got to this point was because the thickness of the fence was not sufficient to allow me to cut a small amount of material off in the early passes. In my muddled thinking, by positioning the wood between the bit and the fence I could adjust the fence to take off the small amount that I wanted to.
The solution was to add some additional thick MDF pieces to the fence (and which I made extra long to assist keeping the skirting board vertical and straight.) and voila...problem solved.
The truly frightening thing is what would have happened to anyone standing in the way of my missile.
