Charlotte
I've been making a trammel for my router but have run into problems.
The internet says that the "done" thing is to remove the plastic sub base that comes with the router and replace it with a 6mm MDF home made one. I've found that the base casting is lower around the bit so I figured that since I don't need a particularly deep plunge, I would sandwich the factory sub base with mine. I found that the screws (M4?) are a weird pitch. Anyone any ideas? should I just drill and re-tap? I'm pretty worried about doing it as I don't have a pillar drill.
C
C
