wobblycogs
I've just finished a little routing and I was taking the collect out to clean it when I noticed a few small spots on the inside of the spindle where the collet rests. Closer examination revealed it to be the dreaded rust! I rolled up a bit of 400 grit W&D into a cone and gave it literally just a couple of touches to remove it but it's got me a little concerned because this isn't an (easily) replaceable part as far as I can tell. I'm happy I won't have upset the balance of the router.
My question is why has rust formed and is there anything I can do about it. After a routing session I take the collect off and blow out any dust and then screw it back into the spindle (making sure not to squeeze the collet without a bit). I'm guessing that a few fibres of wood have remained in there and absorbed a little water or something. My only other guess is that the collet and the spindle are slightly different types of steel and that is causing some oxidation - there is no oxidation on the collect as far as I can see which is why I've considered this. I've now taken the collet off and stored it separately.
Would a little oil be safe? Don't want the bit spinning in the collet obviously but I often go a few weeks between getting the router out for a play.
