Froggy
Hi again, I checked the router manual (bought in the UK not France) and it is indeed imperial. I also checked the router bits and they are also imperial. So, more by luck than management, I am using the right bits and collets. The problem is obviously something else. I checked the collets for dirt and other abnormalities, but found non. I also checked the collet nut which appears fine. I then put a collet in the router and then a bit in the collet and without even putting the nut on I just forced, by hand, the collet in to place and had a real stuggle to get it back out again!! No spanners involved and without even starting the machine. Does this mean I have a faulty router? Could I fix the problem, or should I send it back to the suppliers?
