I used to have a small horizontal router table in my previous shop that I mostly used for mortising to make wood paneling and small cupboard doors. I seem to remember that I saw it in some woodworking magazine, and they called it a mortising table. It had two tables about the same size fixed at right angles, with a slot for the router bit on the vertical table. It was made of plywood with arborite (formica) glued on it with contact cement. The router sat on a little sled, that could be moved with a wooden handle attached to a threaded rod.
I am thinking to build a slightly bigger one as I need it to make some windows and doors.
Anyone have any recommendations for the design? In particular the lift for raising the router?
