Update:
Picked up the plates this afternoon.
Aluminium
The 3 lines running the length of the plate were laser etched and could be used to help line up fences, etc. There are also 4 holes centre marked near the corners and 2 more near the disc\ring recess for router pins. These are just marked and you'll need to drill them yourself. These centre marks aren't visible in the pictures.
The recess for the rings\discs was done so that the ring\disc sits 0.1mm below the plate surface, allowing you to shim with paper to the required height.
Spoke to the machine shop owner and it transpires the machine operator didnt do the recesses using the same machine\tool as last time, hence the crazy amount of hours that they spent. Why? He doesn't know, but I bet he must have had some words with him.
He did say that should we get some more done - he would quote for them. The initial quote was £4-£5 and I worked on an assumption of £4.5. The amount paid was £5 as it didn't seem right to hold him to a mid point considering they did these at a large loss. I'll be adding the extra 50p to everyone's shipping costs.
Will wrap one of each (AL and MS) to get the weight and then let everyone know what the shipping costs are.
Intend to get these collected by next Wed at the latest by the couriers - likely to be City Link, on a next day delivery. With the exception of Luciano, whose plate will go DHL to Italy.
If you haven't sent me your address details - now would be the time, if you want it delivered this side of Xmas.
Dibs
