Makesawdust
New member
I want to use rout several parts from 18mm mdf sheets. I am making jigs at moment and going to use guide bush on router rather than bearing guided bit. I was going to have them cnc machined but the cost quoted is stupidly expensive.
Guide bush will work with 6mm bit and I realise only cut about 5-6 per pass. My question is which but to use, What is best diameter to use and which make Type would be best for cutting. Is 6mm best diameter for cutting or use smaller cnc tooling.
Many thanks
Dave
Many thanks
Dave
