billw
The Tattooed One
Router plate in.
I've just routed out the t-track grooves, I stopped short of where I needed to be (playing safe!) so I need to chisel out the last bits on both sides. Depth seems ok but I used a 19mm bit an the track is 3/4" to it's a tight fit widthwise. I'll just hammer it in and glue it down.
Things left to do include rewiring the router to put the NVR in, make a small box for housing it and then attack to one of the legs. I'll add a few hooks and things to hold the depth control rod, the spanner, and the other collet.
After that I guess it's pretty much done but I might add a couple of drawers into the space at the bottom which can store router bits. Seems a sensible use of the gap.
Couple of layers of shellac for the ply and Osmo for the valchromat and job's a good-ish-un.
