Roofsheet overhang over ply, monopitch roof
JonCamo
12 Dec 2022
Kent
Hi
Putting a roof on my gazebo project. It is monopitch. For the highest face of the roof should the roofing sheets overhang the ply underneath so as not to allow water to ingress over the top of the ply edge as per the mock up photo attached?
These sheets have the anti-condensation lining so they do not recommend using foam fillers to fill the gaps in order to allow ventilation so you are left with a slightly unsightly underside. Or do I use fillers at the highest face and if I do not use them at the eaves on the lower face would there still be enough ventilation?
Hope that makes sense
Regards
Jon
    1.6 MB
I am not a big fan of anti con fleece backing as I think it doesnt really solve any problems. Strongly recommend you install a breather membrane between the ply and steel sheeting (which is what all commercial fully supported steel cladding systems use.. I would also recommend a small flashing at the top to full cover the ply edging. Flashings should all have a welted edge
Thank you Hornbeam
I have a corner trim to put along the edges
Regards
Jon
