Doug71
I am trying to sort out a few damp problems in my mothers house and when I was up in the loft I realised the loft space isn't vented and there are definite signs of condensation up there.
It's a straight traditional pitch roof with a solid 9" brick gable at each end, only about 5 m long and probably 7 m deep (length of gable end). It was re roofed probably 40 years ago with flat concrete tiles and traditional felt, it's a typical cold roof space with fibreglass insulation laid over the ceiling and joist. There are fascia boards front and back which I think the tiles just sit on.
What is the best way to vent it? I have seen the vent type tiles (I presume you need to cut the felt underneath them?) or should we put some vent bricks in the gables, is one way better than the other? How many are needed and where should they go?
I have a roofer coming on Monday to look at the flashing round a chimney so was going to ask his opinion but thought I would run it past you knowledgeable people first.
Many thanks, Doug
Many thanks, Doug
