samhay
Somewhat usual story - I am slowly converting shed into a workshop.
Difference is that the shed is a brick and stone pent style, created by knocking through the old outside toilet and coal shed at the bottom of the garden. Yes it is as small as you are probably thinking, about 10' x 5'.
Having put a decent DPM down under a floating wooden floor, I now have a nice dry shed. Next step is the roof. This was replaced a few years ago and is traditional slate with battens and, what appears to be a breathable (not felt), membrane over the 4 x 2 roof joists. I would like to board out the ceiling (underside of joists), so figure this is the time to put in any insulation. Major priority is sound proofing rather than heat insulation, but some of both would be nice.
Venting is a problem and the reason for the post.
Access to the barge board is restricted and the ridge board is fixed against the high wall with coping stones and lead flashing above, so no obvious way to get any ventilation through the roof space.
If I fix insulation between the eves, what's best practice?
1. use a 70mm insulation board and leave a 25 mm gap on the cold side, relying on the membrane to allow the space to breath.
2. push insulation board or fibreglass insulation hard against the membrane, so there is no gap. I see mention that the requirement for a gap can sometimes be relaxed in this case. I guess slate, which allows reasonable airflow, may be such a case as long as the membrane is breathable?
3. something else?
In any case, I am planning on putting a membrane (or taping the joints if using e.g. Celotex) on the warm side under matchboard, but would welcome any suggestions.
Thanks,
Sam
3. something else?
Thanks,
Sam
