when I said the jigs can take a while to setup, I meant "in the round" ie there are a great many different jigs rather than the elliptical grinding jig specifically (For bowl gouges). When you want to grind your roughing gouge...another jig.....skew.....same jig but different form (open seat/closed seat etc). Now I'm not complaining about Tormek's jig quality...they're excellent and as has been said, most other manufacturers incl Sorby buy them in and ship with their own product. It's just the sheer number of variables and fiddling needing to be adjusted that drives me nuts.
The Pro-edge has two massive advantages:
1) almost all its positions are baked into the machine so whilst less flexible than the Tormek which is infinitely variable, its much faster to setup and in the main, its baked settings include all the ones you're likely to want so no problem.
2) It removes large amounts of HSS VERY VERY VERY much faster than the Tormek even with the silicon blackstone, which is in fact, as slow as a dog. Sore fingers and considerable frustration if you want to regrind a large skew or do an experimental change grind on a bowl gouge. The PE is incredibly fast with a new 60g belt.
In the end, the Tormek is much more refined, but more fiddly, more time consuming, more expensive. The PE is a superb design for wood turners who want minimal faff when sharpening all the usual tools (including carbide tips with the right belt). I really get on with it and have all but abandoned the T7 except for one specific bowl gouge long grind setup which its left permanently. I've no axe to grind with the Tormek (pun intended), I've just found the PE to be way faster and more practical.
