Evergreen":2q8x528u said:
...My 044C works just fine but like all planes of this type, has tearout problems with tricky grain. It'll be interesting to see how this new plough copes with a bit of dodgy grain.
The bedding angle is the same. That and in conjunction with what Dave mentions (no mouth, taking too heavy a cut in the wood one is working) will ensure there will be tear out.
You can try using a back bevel on a spare iron until the cut is blow the surface. Set lightly it should work.
When I am working on difficult grain, I have done one of two things. Carefully used a mortise guage to mark out for the groove, or simply knifed the lines with a marking knife. In both cases a very light cut for a few passes. Once below the surface, it may still take a relatively light cut compared to non-wild grained woods, but for a piece of furniture it doesn't take much longer.
Also, while a plow does not have a mouth, it helps to make sure the skates are truly flat along their length as well as straight in-line to each other. If the skates are not flat and the point where the iron is bedded is higher than the tow or heel, the iron needs to project further than it ought. This can lead to problems (and this condition is not uncommon) due to iron flex and make the start/end point more difficult.
If the skate is twisted or otherwise the front/back parts of the skate out of being truly in-line with each other, it is also a pain to make a decent groove and can affect the alignment of the fence to the body. If the fence is off, that also makes starting a groove difficult.
Take care, Mike
