TobyB
Got a new lathe - for 18 months I learned a lot using an inherited Arundel Junior which I added a Supernova chuck too - but very limited in size of wood that could be turned, and so I bought a much larger and very impressive Wivamac.
I can now try to turn the larger bowls and platters I fancied making ... but ... find new problems, maybe related to the much larger diameters I'm working with ...
I keep getting ripples, especially on the outer face (so I find there is a chattering sensation at the gouge tip as the wood is no longer quite circular), which I can only get rid of by cutting away a lot of wood, typically using the tip of the gouge - which then leaves furrows in my attempt to get a nice smooth progressive curve to the edge when using the bevel (downhill, as the books describe).
I never noticed this much on small bowls and boxes ...
Any idea what I'm doing wrong, or could do better?
Toby
Toby
