Steve Maskery
Try rubbing it off as hard as you can, after just a few minutes, before it starts to get sticky.
custard":ij0ypzbg said:You've got to remember that finishing most highly figured timber is a bit of a special case. Rippled or fiddleback figure is caused by the normal grain pattern being interspersed with fibres that flow in a "wave" like pattern. Consequently some of the fibres are effectively end grain and so will drink in the finish and require several coats to even out the blotchiness.
When I'm oil finishing rippled Sycamore or fiddleback or quilted Maple I'll firstly sand finer than I normally would (say down to 600 grit), then I'll apply the oil based finish generously and keep agitating the surface for about fifteen minutes, then I wipe off the surplus, wait for it to cure and repeat at least for a second time but more likely three or even four more times. You must regularly agitate the generously applied surface to bring fresh finish to those "end grain" fibres, but you must also wipe off all surplus to avoid a thick and sticky surface film. Success is all about striking the right balance between these two elements.
