Thanks for the review - very comprehensive and nice pics. Are you serious about the above comment? I can see this system would be perfect for cutting 8x4 sheets, but what about cutting a 3ft length say of 8" wide wood into 2" strips?
Absolutely serious - you should have seen the cursing as I learned how to rout aluminium without an end mill... :roll: I'll post some pictures of the end result in due course.
What you are talking about Gidon, if I understand you correctly, is the issue of ripping a series of thin strips off a board that will quickly become narrower than the guide rails: that's where the clever clamping system scores:
The above picture shows the underside, with the clamps holding a piece of wood to achieve just this sort of operation (a tapered cut, in this case). Not quite as quick as a sliding cross-cut sled, but perfectly 'do-able'. It can be set up for repeat cuts with an aditional accessory, which I don't have.
This link illustrates the full range of clamping options:
http://www.eurekazone.com/products/detail/smartclamp.html
That said, it's all a compromise: to be brutally honest, the task you describe would be accomplished on my floor standing bandsaw, for choice. That's why I've got rid of the TS - it's definitely redundant with this system and a bandsaw. However, the above shows that it is perfectly feasible to make such cuts with it if one were 'on site'. If space is a primary concern, it's definitely a good option...
