Won't help with shaving hairy Italians.Peter Sefton":378dlel7 said:Jacob":378dlel7 said:effectively sharpening the blade yes but not necessarily improving the actual cutting edge.Peter Sefton":378dlel7 said:I believe stropping is sharpening the blade and improves the cutting edge, ...
Compare it to polishing the sole of a plane - it can appear to very effectively improve the action of the plane as if magically sharpened but without having any effect on the cutting edge at all.
Similar effect with other edge tools but the obvious disconnection less clear cut.
When teaching sharpening I will often show students how you can improve a blade from not cutting hair to razor sharp cutting hair in two or three seconds on a strop, I says it's sharper-you may say I waxed the sole of my plane, what are you on about?
I know we cut timber not hair but it's a teaching aid.
Cheers Peter
What - the frantic polishing you spoke of so derisively? Make your mind up. :roll:Jacob":21n6clmc said:Unfortunately it happens to have been omitted from the rigid codes religiously followed by modern sharpeners - so the idea is anathema - but I don't care!
No - the very minimal polishing you get with stropping.bugbear":pn9ddqre said:What - the frantic polishing you spoke of so derisively? Make your mind up. :roll:Jacob":pn9ddqre said:Unfortunately it happens to have been omitted from the rigid codes religiously followed by modern sharpeners - so the idea is anathema - but I don't care!
BugBear
Jacob":1khek1u2 said:Unfortunately it happens to have been omitted from the rigid codes religiously followed by modern sharpeners - so the idea is anathema - but I don't care!
