rowan.bradley
New member
I have just bought an old long case clock (said to be from about 1780) with a mahogany case with some inlays
and want to set about restoring the case myself. I have the following questions:
1. How do I safely remove whatever old sealer, polish and dirt is there, and reveal the true colour of the wood?
2. Having done this, do I need to sandpaper it? What grade paper should I use? How much sanding can I do without risk of damage?
3. Does it need any sort of stain?
4. What is the best treatment for the wood once it's been prepared? What type of sealer? What type of polish?
5. There are some cracks in the veneer where the veneer has raised slightly on each side of the crack.
What is the best treatment for these? Do I need to inject some sort of glue (e.g. diluted PVA) into the crack and then clamp something over to press the wood flat while the glue sets? Or what?
6. There are some places where small pieces of veneer are missing
How do I find small bits of veneer which will match the bits I'm trying to replace? Does it need to be OLD veneer, or will new wood be good enough?
7. The front panel of the base has an old crack in it.
What is the best way to repair this. Remove the panel, take the two parts apart (splitting them apart if necessary), clean up the two surfaces (wire brush?) trying not to remove any sound wood, and re-glue together? Or what?
8. To do the above I am going to have to remove the front panel of the clock base. How do I soften the existing glue and avoid the risk of damaging the wooden panels?
9. If things need gluing (e.g. the crack mentioned above), what sort of glue do I need to use? Can I use PVA, or do I need to use some more old fashioned type of glue? What would a professional restorer use?
10. There are places where the case has taken some knocks and bruised the wood.
What is the best way to treat these?
11. Which order do I do all thee things in?
- fix crack in base panel
- replace missing veneer
- replace any missing bits of wood
- glue down loose veneer
- deal with bruised wood
- strip off old polish, sealer, dirt
- sand paper
- stain (if necessary)
- seal
- polish
12. I saw in an American web page the suggestion that the best treatment for antique wood was penetrating oil, followed by wax. Is this really a good treatment? What sort of penetrating oil? Surely not the sort loaded with graphite? What is the best oil to use for this purpose? And what is the best wax?
I hope that someone can give me advice to get me started on the right road to restoring this clock, or can recommend a good book that answers these sorts of questions.
Thank you - Rowan
- sand paper
- seal
- polish
Thank you - Rowan
