Alf":2gj9i0z3 said:
Jake Darvall":22ktn6vf said:Took a photo of a stanley 50 blade in a stanley 45 that I used today.
Thought it might be relevant here.
The blades not thick enough to bind up.....easy fixed with a shim....like I was talking about last post.
Can see the shim sitting on top of the blade there.
Jake Darvall":8mrt20us said:![]()
Generally do you think the 405's is better made than the 45 ? ..... cause thats something I've noticed in other record types. More rugged.....skates straighter....that sort of thing. eg. I feel more care has been put into the making of my record 50, over the couple of stanley 50's I've got.
dunbarhamlin":6adztfqb said:[*]Also, I think the fence attachment/adjustment is better on the 45 - far rather have thumbscrews than have to mess around with a screwdriver.[/list]
Jake Darvall":3jx0k7bn said:I have noticed when using the fine adjust the face turns askew a little. Which is a bit of a worry I thought .....also I had trouble with locking its setting fixed.....the locking screw would lock one side only but not the other....cause a little wiggle.
Really feel those are big problems. They both must affect the cut.
I've given up on my fine adjust.....now just keep it all bound up tight out of use...which is a shame, because when it works well the fine adjust would be a handy feature. Better than the stuttered adjustment of the fence arms on those rods. uno.
