repainting a graduate
paul-c
19 Nov 2009
liverpool uk
hi has anybody out there repainted a union graduate
my graduate could benefit from a repaint / tidy up before i fit the new motor and electrics
i am looking for some advice on a suitable paint to use to give a good result fron hand painting
cheers
paul
Hammerite smooth has a green paint, don't know how close it is but usually it goes on easily without brushmarks.
Have an older Nutool lathe than the one I am using someone
used it for wet turning & all the motor casing is rusty so I am
about to use the green hammerite as it is supposed to suppress
the rust as well as look a lot better...
I do quite a few graduates.
First strip it down and power wire brush all over (cup brush in a angle grinder) then hand sand with emery cloth. fill any chunks missing with body filler, sand after,
then use hammerite grey hammer finish and apply with a small foam roller.
Then touch up in hard to reach places with a brush ( stippling action)
perhaps do 2 coats with 2 hours between
Power brush the bright areas, power sand the flat lands and alls done
Ian
