Nads
After lapping the back of a chisel/plane iron and honing the bevel to the required angle, what’s the best way to remove the wire edge, which is created by sharpening process. I’ve heard people say you can dig the blade in hardwood (is this the end gain of normal grain?) Or is it best just to genteelly lap the back of the blade and then sharpen the bevel side alternately until the wire edge has gone? Some advice from you guys would be great!? :?
How do you guys compare diamond against water stones? As I currently use waterstones, but have heard loads of good things about the trend double sided diamond stones! :?
Cheers Everyone!
Cheers Everyone!
