sue denim
This last week I took a timely approach to a bowl made from Sapele. This is not an exciting piece of wood but this was an exercise for me in using scrapers on the inside.
I sanded the outside until it was really smooth, going down to 800 grit. I used sanding sealer before sanding and then applying a friction polish. I was able to obtain a mirror like finish to the majority of the bowl with the exception of a small area about 5mm x 15mm on the edge of the bowl. No matter what I do the area will not take the friction polish. I cannot be applying incorrectly as the rest of the bowl is really glossy smooth. The area shows a dull patch.
I have given up trying to remedy the situation with friction polish and now seek an alternative finish.
Question 1 . How do I strip off the old wax without going through reams of grit and starting over ?...
Question 2 . Which polish should I buy that will give a real deep polish shine ?...
The bowl in question is 80mm tall and 250mm diameter with a wall thickness of about 6mm.
I know many prefer a matt finish to their work but this is me trying to prove to myself that I can do it.
Thanks in advance and when it is done I will post a picture
