OPJ
Hi guys,
For a long time, I've suspected that the bearing just above the chuck in my Clarke pillar drill may be shot. It rattles a bit while it's running and it only started doing this about a year after I bought it (...I think I've had it for four-years, now!
It doesn't seem to affect the performance or accuracy, as far as I can tell but, it's annoying.
Trouble is, I'm not sure how to get the old one out:
The chuck can be removed easily enough, by hitting the other end of the shaft.
Do I need to remove the taper first or is there another way? I've heard that you can do this by making a pair of wooden drifts...
Secondly - does anyone have any recommendations for suppliers of bearings and V-belts? My drill's belts are also looking a bit worn and I'm sure they've stretched, which is why I can no longer tension them at certain speeds.
I've used Simply Bearings in the past and I couldn't fault them. They don't appear to sell belts and I'm assuming it'd be cheaper (not to mention easier!) to buy both from one place. I'm also guessing there are many sources who'd be cheaper than going through Clarke or Machine Mart directly! :shock:![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Your help would be much appreciated.
Thanks for looking,
Olly.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![4939202394_8a7f004eca_z.jpg](https://proxy.imagearchive.com/761/76176a3d44c85feb0f90e44a42771caf.jpg)
![4938617313_9e2f13db61_z.jpg](https://proxy.imagearchive.com/b54/b54e597c0e59da3ccdb680feaa75660a.jpg)
Thanks for looking,
Olly.
