Spectric: Yes, but I'd like it transparent. Admittedly, I didn't expect all this trouble!
Because all I could find had a 2mm wall, much too thin. I'll check that link, thanks. If a 40 x 20-25mm bore was available, fine. I'm not mad, cough.30,32,34 & 36mm bore off the shelf
No 'Shock Horror' as far as I'm concerned - most hard woods can be treated just like metal or industrial plastics - the biggest problem is getting mixed swarf. Separating wood-dust from brass/alum/steel swarf can be a real pain!I work mostly with metal but sometimes turn plastics and even (shock horror!) wood on a metalworking lathe.
I suspect that the initial "drilling with a 25mm flat bit" was a major mistake. Flat bits are not known to be 'sharp' so the friction (and consequent heat) would be high. Personally - assuming I needed a smaller bore than the 30 available as Acrylic tube - I would have started with something like a 6mm HSS jobbers drill progressing in 1 or 2mm increments until I could get a boring bar in. My preference would then be to use HSS tools with a 30º+ top rake and take light cuts (<1mm) until within 1mm of the finished bore then <0.2mm at a higher speed.chaoticbob said:Graham - unless you need to reduce your minimum spindle speed for other reasons, this is not the way to go. 450 rpm is not fast for turning acrylic at these diameters. I have gone much faster using CCGT carbide inserts, which are intended for aluminium but perform well with other soft materials. I'm not sure how they could be used in a wood turning lathe, but the message is that they are sharp and have a lot of top rake.
Acetal can't be polished to a clear finish.If it doesn't need to be acrylic, the easiest plastic to machine is acetal.
I'll concur with that on both counts !nick61 said:Tricky to get nylon to size with a good finished.
I'm making the assumption that you have a metal working lathe and/or that you can hold a boring bar in a firm position and control its progress by machine dial rather than just by hand.I take it a boring bar is what I christened a "side-chisel"
"then use HSS tools with a 30º+ top rake"
? I'll look that up!
In that case you haven't found the right Engineering Plastic suppliers, try Direct Plastics | Engineering Plastics | Large Stocks In All Sizes or Cut to Size Acrylic (Perspex) Sheet, Tube & Rod - Simply Plastic both easily found 'Engineering Plastics' Suppliers.Acrylic isn't listed by 'engineering plastic' suppliers I've found
