Reducing tearout from router plane.
AESamuel
15 Jan 2015
Falmouth, Cornwall
Hi,
I was wondering if anyone has any tips for reducing tearout while using a router plane, particularly in soft woods? I've read that the spear point blades can help but I only have straight blades.
Thanks!
Read the grain direction. Work across the grain if you can. If working with the grain, and this is cranky, knife the side wall deeply.
I dislike the spear point blades. Don't see the point. I believe that their intended use is are for finishing.
Regards from Perth
Derek
The spear point blades are for working the undercut in a dovetail housing, where the floor has to be clean and smooth for the joint to work.
In a shallow housing or groove you have to be careful not to undercut the edge too much (or at all) or it can crumble. It's easy to get carried away with this cutter and start jabbing the walls of the housing or groove you're cutting.
Hi, has any used the
Quangsheng Small Router Plane​
It’s on offer at workshop heaven currently and looking at investing, don’t think I need a big one just not sure on it actual size can’t find any yt videos or anything on it.
Thanks in advance
