TobyT
I want to fit the Record 52 1/2, that I purchased from the tip, to my new bench. Unfortunately I bought it over a year ago and took it apart for cleaning and never quite got round to fitting it back together again...Which of course means I've lost all the screws.
What size do I need? Reading through other posts it looks like the face screws are 5/16 Whitworth CSK. I'm less worried about these, but I'm assuming the other missing screws will also be Whitworth. How do I size these up (the outside of the hole looks to be about 7/16 but not sure what that equates to in thread terms)?
The screws I'm missing are labelled R in this diagram (which I found when working out what pieces I need to dig out from the depths of the pile).
http://www.activeeducationsolutions.com/default.aspx?id=308&n=223&cid=0&rid=0&catid=0&page=1&pid=864
Would it just be easier to tap a metric thread? I've never tapped a thread before, how do you go about re-tapping an existing thread? Get a slightly larger tap and then wallop it with a hammer?
I'm also missing screw K and the pin that holds the screw in, but I'm assuming I can bodge something to keep them in place.
As an aside, why are the spares priced so highly? The screw assembly is over £100, you can buy a new vice for less than that.
