Record saw losing blade tension
Phill.
Have you contacted (Record) regarding this problem, as they are very good with warranty claims, I had a problem with a bobbin sander, they repaired it once under warranty, but when it failed with the same fault for the second time, they replaced with a brand new machine no questions asked.
Very good customer service. =D>
Take care.
Chris.
PS. If you did not purchase from Record direct, contact your supplier first.
Chris,
I haven't rung them but I have submitted a ticket through their support page, but I've still not had a reply.
My problem is, living where I do, returning the saw for repair would be very costly. Also I am pretty sure having disassembled it and played around with it as I have any warranty would be well and truly voided.
Regards
Phill
Fingers crossed that the part on its way to you now will rectify the problem. :)
I'm sure it will, thanks. And, it looks like a better arrangement than the original.
Phill
@NazNomad.
The part has arrived, it's all put back together now and working a treat.
I've just spent the last hour working on my latest project.
Chuffed to bits :D :D :D
Thank you so much NazNomad.
The only fly in the ointment is that Record have finally gotten back to me and they want to know when and where purchased with a view to arranging to get the saw collected :shock: Oh dear, I can't see them being to suited at it having been taken to bits and having an SIP tensioner fitted!
I'll ask them to just send me a replacement tensioner so that I have it.
Meanwhile I think the current repair is better than the original.
Phill
''HAPPY DANCE'' Glad it fitted ok. :D
Remember, never throw anything away. :oops:
Record have gotten back to me and offered to send a replacement tension screw if I don't mind fitting it.
Phew, that's a relief, sending the saw back now might have been a bit embarrassing!
So new tension screw on its way....
But then so is a second hand Delta :D
Phill
