Record CL4 tailstock 'niggle'
Neil Dyball
21 Jul 2008
Framlingham, Suffolk
Hi All,
I have a CL4 which I'm generally very happy with. However, I do have a small niggle with the tailstock.
The 'wheel' which propels the quill(?) in and out has what appears to be a small thumb notch in it. When turning the wheel repeatedly during a drilling operation this is really inadequate. What it really needs is a handle on the wheel which projects out backwards, as I'm sure I've seen on other lathes although they may have been for metalworking. I hope that makes sense as I realise it's not very 'technospeak'.
Anybody else had this problem and got an easy solution, or know of an aftermarket solution? Unfortunately I don't have metalworking/welding skills or I'd have tried fabricating something.
Any suggestions gratefully received.
Cheers,
Neil.
My Coronet number 1 (?) has a handle just as you describe.
No idea if it's standard as it was there when I bought the lathe.
You could turn yourself a handle, bore a hole and drill a hole in wheel and attach it with a both - shouldn't be too hard.
Note that the wheel on my tailstock is at the end of the tailstock, rather than in a slot cut part way along (which seems kind of limiting to me).
Had the same frustration with a CL4... made a handle to fit,
sorry Neil, I just can't remember the details... rather than drill the cast wheel I think I shaped a wood filler for the gap between the 'spokes', sandwiched it between two shaped scraps of ply and bolted a turned handle on... watch the clearance, I recall having to do a bit of fiddling :wink:
Thanks for the replies chaps.
Looks like I'll be turning a handle this weekend and bodging it to fit, unless I can find a friendly engineer to weld a metal one on!
Cheers,
Neil.
I'd be a bit careful welding - if it's a cast handwheel it would need to be heated well in advance to prevent cracking. Better to drill and tap a hole in the edge of the rim. Then you could either stick a bolt in as a temporary fix, or get your engineer to turn a nice metal handle.
Neil
I had the same issue with my old CL3. I simply used an old side handle off a hand drill. The cast handwheel on the lathe was very easy to drill and I attached the handle with a bolt and nylock nut so it rotates as the wheel rotates.
