Ttrees
Iroko loco!
Dude , that's a ripping blade ....
you need way more TPI for cross-cutting .
Even if you did manage to get straight cuts ,there would be a very rough surface left and
it would probably blow out underneath the timber and the end of your piece would suffer
severe spelching aswell .
Not to mention I would not be using a blade that wide in a saw like that .
You could have damaged your saw allready !!!
I presume that if you made your fence parallel with your mitre slots and adjusted your table
mounting for drift on say a 1/2 " blade RIPPING long grain and got perfect results ,
you would still notice drift crosscutting .
A tablesaw or mitresaw is the tool for the job really ...or cutting by hand with a shooting board
to clean up .
Good luck
Tom
to clean up .
Good luck
Tom
