Hello,
2 things are obvious from the photos, although tension and tracking cannot be ascertained from a photo, so it could be a combo of things.
But 1. the side guides are not forward enough, they should be just behind the tooth gullet and 2. That is a small tooth count blade for thin stock. Looks like a 3 TPI? If so I wouldn't cut less than about 1 1/2 in thick. That board looks thinner. Especially cross cutting, that blade is better ripping thick stock.
I wouldn't pay too much attention to the Snodgrass video. Set your blade tracking in the centre of the wheel, tracking with the gullets centred is just a show trick for his crowd/video. There is no logic to it, apart from not having to adjust the guides. But it limits the blade width you can use. His contention that a blade needs to be supported at the teeth is tripe, quite frankly. The wheels just make the blade move. The support comes from the guides. Those little saws he demos on will not take wide blades, so it makes little difference, but a wide blade tracked at the gullets leaves an awful lot of the remaining width dangling in space. Now think about where the tension is and how the blade will deflect, it will actually be angled down at the back. ( or trying to) How will that cut straight. I don't know, either. Conventional wisdom from millions of bandsaw users and recommendation from manufacturers say track centrally.
Mike.
