Record 53 vice - rocker bar size?
Deadeye
21 Aug 2017
Buckinghamshire
Hi
This week's project is refurbishing my father-in-law's Record 53 vice.
The rocker bar is missing, although the lever, spring and everything else appears present and correct.
It looks like a straightforward bit of flat steel. Does anyone have this vice and could give me the dimensions? It looks c. 470mm long would do, 4.6mm thick... it's the width I'm most unclear on.
Many thanks
brilliant - thank you.
So sounds like 3/16" thick by 18" long by 91/64" wide. Hmm. I was hoping that 5mm x 25mm would do!
Hmmm.
Well, the half nut runs up and down the length of the bar, so it needs to be correct the whole length.
Just reassembled enough to measure up... gap looks like 25mm, so 1".
Time to change my order!
