Got an issue with an old Record 53 vice. It tightens up just fine but won’t loosen - when I unwind the handle two things happen. First the handle and moves away from the jaw by a few mm (pin at the other end is there but looks like not enough washers under it). That might be a red herring though.
The next thing is that the QR lever moves until it reaches a point where the half nut releases, the spring pushes the lever and nut back on but without any movement. The QR itself works fine and I can open the vice that way but it’s not ideal.
I’ve tried adding more spring tension - the bolts holding the half nut brace in place gave up and the entire thing failed. Tried removing the QR and packing out the half nut. This worked until those same bolts failed holding the packer/half nut against the force of the thread.
Ideas?
Ideas?
