Record 311 plane
Cub21
20 Dec 2020
Derbyshire
Does anyone have a record 311 plane as you can remove the front section and replace it with a short bull nose but I would like to know the dimension of the bull nose can any one send me the details please
regards cub 21
You mean the plate that screws onto the bullnose when you take the large front section off? I'll measure mine for you tomorrow.
Morning Cub 21, assuming the part in the photo below is what you are looking for, mine is 10.3mm (13/32). Seems an odd measurement and it does vary by about 0.15mm across the 4 corners. Whilst I use my 113 quite a bit I don't think the bullnose attachment has ever been used as I tend to favour my No90. Hope this helps. John
    63.7 KB
    119.1 KB
Mine is 48mm long x 28.5mm wide x 9.5mm thick measured with a ruler
in old money 1 7/8" long x 1 1/8" wide x 3/8" thick
hope that helps
Thanks John and mikej460 that will do nicely I will have a look at no90 thanks again
just on the off chance you may know or have I am looking for a record router plane
regards cub
