Alf":3ghhs1ba said:
...Snip...
Well with a straight blade you apparently have to balance the plane, square and level, on that high edge and plane down, square and level, until you're taking full width shavings. With a cambered blade you've effectively got three ways to take a shaving, 'cos it's kinda shaped like \__/ (exaggerated to the point of craziness). So to get the / edge like __ you'd rest the sole of your plane on the edge of the work so the left edge of the blade is doing the cutting. i.e. Making the shaving tapered so the thickest shaving is being taken over the highest point, with it feathering away to almost, or even, nothing at the lowest edge. It doesn't depend on you being able to balance the plane square on only a tiny portion of the edge, so it's much less demanding on your own sense of what's "plumb". You keep doing that 'til it's square, moving the plane sideways as required to square up the edge. Does that make any sense at all? :-s
Cheers, Alf
Oh, the contrarian in me rises once again :lol:
Obviously there are at least 2 more ways of accomplishing any given task than the number of people asked...
"My" way? Aside from the ghastly admission some time ago that I have and use a R / L-handed pair of #95s, when I use, say a #8 or #6 (yes, I own two #6s...how's that for useless <g>) and I care a long board's edge is square to one face or the other, I just use that little lever thingy to adjust the blade a little. I was told this would produce a tapered shaving.
Even to the point that one could have the entire plane all but centered lengthwise down the board and take a shaving that tapers down to nothing. Just by moving a little lever and not balancing the plane precariously on a board's edge or nearly off one side of the board in order to use the opposite side of the plane.
But then, on glue-ups that involve large panels, I just use the method Roger uses. Angles compliment each other and then as long as a little care is used, the boards fit properly.
I'd stick a link in here showing a display case with its glued up top of Bubinga (which should make seeing the joint easy) that was edge jointed with the cute little #95s (it's only 20" long or so) and offer a fine prize if someone can find the joint in the pics, but what's the point
We all have and use methods that someone told us about, pointed us to another, such as DC, or maybe even reasoned out for ourselves. It's all good. Most advice will produce the desired result. The thing that
really takes practice is being open to try other ways, giving them our best effort.
