garywayne":3axs59ih said:
1/ Record 0120 block plane. (6 7/8").
A #110 with depth adjustment, so my Record catalogue tells me. Any good?
2/ Stanley SB3. (8 3/8") Not used.
Very wise. However, it has potential as a scrub plane according to some.
Either by Chapman or Stanley GB's secondary line after they'd acquired them. Never had one but I bet BB could comment on whether they justify any tuning effort.
4/ PM No.10. (10"). Sorry, I forgot the name. It has a very short blade that goes right to the outside edge of the plane.
Ah, one of those Paramo planemaster things or whatever they're called? Apparently rather frustrating to use.
5/ Hilka No.4. (9 7/8"). rubbish engineering.
Yep. They
can be made to work, but really it's hardly worth the effort.
6/ Record T5. (12 3/4"). Nice plane. £15.00 car-boot.
Vrooooooooom... I choke in the dust of such a beautifully teed-up drive-by gloat. The pick of the lot.
So what would be a more useful one?
Depends what you're going to be making, but if it's going to be cleaning up tenons and rebates and etc then personally I'd unhesitatingly choose the LV medium shoulder. But, I have a feeling price may be the stumbling block? So, might I suggest instead of
getting the impression that this plane is a bad investment.
you start to look on it as a
good investment that you sell on for a good profit towards a shoulder plane. And then maybe look out for an unremarkable but useable craftsman-made infill shoulder plane, which can sometimes be had for sensible prices if you're fortunate. Or talk to Peter Maddex about making your own... Or you might get lucky on a Stanley 9X series and find one that actually works I suppose.
I would also like a jointing plane No.7 or 8, but that's out of my reach at present.
How d'you feel about wooden planes? A wooden jointer can be had cheaply, or again, you could make your own.
Would someone please explain the pros and cons of the low angle and standard angle plane angles.
You're thinking of block planes I assume? Standard angle gives a more robust blade bed with less likelihood of damage to the rear of the mouth (which used to be an issue before modern materials). Low angle gives you greater flexibility of angles depending on the bevel angle you use on the blade, a lower profile plane to hold and is generally a more useful type all round.
Cheers, Alf
