Racers
- Joined
- 22 Apr 2005
- Messages
- 9,172
- Reaction score
- 136
Hi,
I bought a Record 043 from Blister, he had picked up from a car boot with the usual parts missing, namely the blade clamp and depth stop.
I thought about it for a while, no point rushing these things, eventually I came up with some solutions.
The blade clamp was cut from some brass with the help from my Startrite 352 and a metal cutting blade. A bit of filing and it fitted, because it was only 1/4" thick I decided to use a 4mm clamp bolt so it was drilled and taped at 4mm. I also drilled and taped a the head of a brass bolt to form the bolt head.
The depth adjuster bolt was missing and I hadn't got a bolt of the right size, so I taped it out to 5mm made another bolt head like the clamp for it.
the depth adjuster was made from some Stainless Steel and some steel bar that fited the hole. I filed a shoulder on a length of bar using my drill press and a file (I need a lathe) and drilled and countersunk a hole in the plate and riveted the rod on.
It only took a couple of hours to do, and I am quite pleased with the results.
And finaly my whole fleet of 43s
