Alexfn":2wvnff3c said:mike seems to comment on every post about impact drivers, his comment that it will drive a 100mm screw into 100mm oak post, well my impact driver would put a 200mm screw into a 200mm post in 1/3rd of the time it took the driver to do that 100mm screw, it also wouldn't transfer the torque to my wrist
MikeJhn":2cqmrhwf said:Alexfn":2cqmrhwf said:mike seems to comment on every post about impact drivers, his comment that it will drive a 100mm screw into 100mm oak post, well my impact driver would put a 200mm screw into a 200mm post in 1/3rd of the time it took the driver to do that 100mm screw, it also wouldn't transfer the torque to my wrist
And my mums fridge is bigger than your mums. :roll:
Mike
I've ordered a bosch but I did order the batteries too as I assumed they were different to the 36 volt ones for my drill driver.TFrench":l8jd6m3c said:if you're in the bosch system see if you can get a bare unit to go with the batteries you have - makes a big difference to the price.
