Recommend an Olive splitter domestic plumbing
deema
14 Oct 2011
Cheshire
Hi, I’m after an olive splitter for domestic water / heating applications. I’d like it to be able to cope with 8mm all the way up to 28mm and be effective in plastic as well as copper. Does such a thing exist
Thanks in advance
Try Dicki dyer 15 mm to 45 mm
45mm
£46.64
Toolstation
(31)
By Swoop
View more
Dickie Dyer 652001 Olive Splitter 15 - 45 mm , Black
£36.88
Amazon.co.uk
30-day returns
it can be hard to get olives onto plastic pipe before they've been tightened let alone after. I've cut olives using a dremel then when your close to the pipe put a screwdriver in the slot then twist. use the fernox silicon paste on that bit of pipe in case it's scratched it.
I've got a pair of olive cutters (look like a pair of pliers in a way). They make it so much easier to remove an olive - way better than with a min' (typical 6") metal bladed hacksaw.
Monument and Ox Pro (amongst others of course) make them. They are designed to fit over the olive and then you simply squeeze hard to penetrate/cut the olive; after-which it can be removed. You'd need one pair for each pipe diameter.
Tool Station have Monument; Amzon both.
Some olives will cut more easily than others.., brss being the hardest. You can't use these cutters on steel olives..
