Since we moved into a Victorian end of terrace, the floorboards in the bay window half of the lounge have always been a bit bouncy. Our reluctance to raise them all has now been overcome due to being necessitated by central heating pipe work. It turns out the existing joist work in the area is a complete mess, consisting of multiple botched jobs, makeshift wedges, and previous damp (long since resolved). The biggest surprise is actually how little bounce this mess was creating!
Anyway, we are planning of replacing the lot and wanted to get a bit of advice. We’ve raised the boards up to a wall plate that runs across the room, from which afterwards everything seems solid. Our plan is then to install a series of 2-3 new wall plates, which sit on small columns of bricks every so often, and lay the new joists across them.
My main query is how do I go about securing everything together? At present there seems to be a lot of everything placed on top with a distinct lack of fastening. Also, are the wall plates meant to be fastened into the walls, as very little seems to be secured to the wall?
