I logged on to ask a question, and saw that Heath Robinson had posed a similair question in relation to re-sawing stock with a circular saw. Rather than hijack that thread I thought i'd start a new one.
I have some 2" thick oak which needed to be re-sawn. My bandsaw doesn't have the capacity. So I decided to re-saw it on the table saw. The boards were 8" wide, so I started by flattening one face and squaring 2 edges on the planer, then ran the board over the (unguarded) table saw blade, taking say 4 passes to reach the max depth of cut (just over 3") on each side. This left a 2" strip down the middle of the board which was easy to rip through with a hand saw as the kerf made by the table saw provided a nice guide for the saw. Big 3tpi Disston did the trick!
Anyway, it wasn't until after i'd done this that I wondered whether others do the same??? And does anybody have any tricks for avoiding the unguarded blade at the end of the cut?
It isn't a technique I would employ for thin stock, but for wider stuff it worked really well.
Karl
Karl
