Re-finishing a veneered coffee table with a new heavy duty finish
ptturner
10 Mar 2021
avon
Hi all
Took on a job to refinish an oval veneered top coffee table. The customer wanted to remove or improve on the dents and scratches to the top. The legs wont be touched as there is no noticable damage to them.
So far I used a very old bottle of niromors to remove the lacquer, which mostly removed everything and some medium grade wire wool to remove traces left in the pors. However there is still some small dark patches, most likely old finish, and dirt which I am keen to clean out before refinshing.
I am wondering whether to use an orbital sander with say 600 grit to prep it perhaps going to higher grit?
Also what choice of finish, customer wanted a poly varnish for durability, however are there other alternative that are easy to apply with a brush or cloth and be as durable to hot cups, spillages etc?
Some pics of the stripped top, I tried a steam iron on the dents but without much luck at removing the minor dings and dents.
I dig stain the borrowed bedsheet, so lady of the house wont be happy! :LOL:
Any advice appereciated.
    44.1 KB
    48.8 KB
    39.1 KB
    36.6 KB
    40.7 KB
    42.1 KB
I've never actually applied it, and we had spray gear and did an 2 pack lacquer on most things, or the poly floor varnish(+shellac/varnish, oil etc) but I have heard its quite good.
Its a high gloss cellulose lacquer thats heat and water resistant, which is what you were after. Quick dry but also cures over time.
I'd say as with all finishes, multiple coats, light denibbing in between. High gloss, but you can go over it with 1000 grit w&d and matt it off somewhat.
Also forgot to mention suggestions for a satin finish would be good to disguise the dents and scratches that wouldnt steam out. Customer has this table in their conservatry so sun highlights imperfections in the top.
