rafezetter
Troll Hunter
Edit: seems somehow my google-fu completely failed me and I managed to miss raised bed information regarding wood and liners etc in my search but I've found some now.
As per the name - I'm in the process of planning a large (1.6m x 8m) raised bed and I'm utterly clueless on the longterm effects of soil on wood for this usage. I'm trying to make it from mostly reclaimed wood that we have a lot of, so it's not pressure treated.
Would painting it with waterbased wood preservative on the soil contact side have any real longterm benefit?
It's quite probable that I may still be living here in 10 years, so it needs to last at least that, but as long as possible ideally because it would be a major understaking to re-do it for the next people when it rots. 6-8 dumpy bags of soil.
The design is a double skin - using pressure treated 6 x 8 sleepers we have as the uprights sitting on patio slabs - which will be under the line of decking so won't be seen and will be treated with bitumen paint, with 2x4's notched on the back side then clad with old reclaimed larch feather edge (which is 2x thicker than the stuff you can buy now) on the outer face of the 2x4 and.....???? on the inner face.
I've considered teram (soil liner) as a "bag" instead of lining the inner with wood, but that might get damaged if someone takes a fork to it - I don't want to to go the expense of a poly liner on top of wood, so if I just line it with bare (not pressure treated) wood what sort of lifespan can I hope for?
bitumen paint will prolly affect the soil - thompsons water seal - shou sugi ban and smothered with cheap teak oil....?
edit 2 - interesting a mixture of beeswax and mineral oil, really soaked in, or raw linseed oil are good alternatives to extend the life of the wood.
