Raised panels with LN skew block plane
Alf":3j9glynf said:
Cheers, Alf
You emulating St. Roy, Alice?
BugBear (who raises panels with older, less subtle, tools)
http://nika.frontier.iarc.uaf.edu/~cswi ... 19#message
http://www.wdynamic.com/galoots/4images ... ge_id=2753
(the door panels, not the flanking panels)
My method requires a plow and/or dado plane and a jack (I did this one with a plow, it worked fine cross-grain for this application):
Groove and dado up the panel to define the field:
Guage out your panel edge height:
And take the raising on down with the jack, working the cross grain ends first since any chipout will be taken care of when you do the long grain edges:
Here is an image as I approach the end of the process:
I think that even if I owned a tablesaw, I would still do it this way. It is so fast. I might use the tablesaw to do the grooves and dados, or more likely, I would use it as a plce to set my Coke can down. :D
Non-fielded panels can be done with jus the jack perfectly well. That is how I do drawer and chest bottoms. Just remember to go cross-grain first.
-Jamey
He has parrots too? :shock: :lol: Well I always feel a bit of blood on a project really shows you've put yourself into it, don't you? :roll:
Mike, no review, no. It's not a "proper" LN one with the name on and everything. :-$
Cheers, Alf
