In parallel with the fish tank build I will also be knocking together a set of raised beds. These will be around 2' tall and will be build using 2"x4" (approx) decking joists. I plan to wrap the inner surface in membrane to keep the soil away from the wood and hopefully prolong the life span of the "eco treated" softwood as I couldn't justify the outlay on oak. The top of each wall will then have an Oak sliver (maybe 2x1") of oak to hide the plastic. I plan to prefab each wall panel in the garage and then basically but joint each one to form the boxes of the raised beds in situ.
Currently I am trying to work out how to join the joists together to form each wall - something that is complicating matters is I am attempting to figure out how to enable each joist to be replaced separately when they actually start to rot out. This sort of rules out biscuit joints or just screwing each joist to the one below. The the moment it seems to be:
- Screwed to a strap on the outside of the bed
- Pocket screwed to the one below
- Bolted to a a strap inside the bed (would need to do something about the plastic when it comes time to replace
Any ideas?
Miles
PS Will post some pics of the design up when I have a little more time
Any ideas?
Miles
