Dibs-h
The fitting of the guttering on my workshop is imminent. The medium term plan is to have some sort of Rainwater harvesting - using black IBC's.
Now the original plan was to have the gutter on the front of the workshop draining to the left, merging with the downpipe from the new garage roof and going to the IBC's. As per the doodle below,
Vey little thought had been paid to the rear roofs (of the workshop & Garage). Now rather than have them drain to the end of the workshop and to their own IBC - I was wondering whether to have the 65mm pipe come into the building and then exit out of the front? Thereby connecting all the pipework together and filling the same set of IBC's. The width of the shop is around 4m and the 65mm pipe is available in 4.3m lengths - so wouldn't have any joints inside to leak. Any joints would be solvent welded anyway.
Hopefully the doodle below shows the proposed plan better.
Bringing the pipework inside - good idea or bad?
