lastminute
Does anyone know where to buy a hinge mechanism, front and back similar to the festool one?
Peter, I'd seen the Dashboard ones which looked like just the job, and whilst $240 is less than buying a "Full Fat" Festol MFT, it still seems s steep price for a fairly simple aluminium bracket (and I think you still need to buy the rails separately and with their design fit two single T tracks parallel with each other, and parallel with top of MFT but aligned below it, not rocket science I know but plenty of opportunity to go wrong?). If there is no other alternative I might investigate making one / getting one made. And anyway - it's all your fault for making such a good video reviewing the Mafell and Festool track saws and convincing me to go with Mafell ! Seriously - thank you for the video, it was incredibly informativeFestool sell them as spare parts for the MFT/3, or there are these ones from the US.
Peter, I'd seen the Dashboard ones which looked like just the job, and whilst $240 is less than buying a "Full Fat" Festol MFT, it still seems s steep price for a fairly simple aluminium bracket...
That looks good, how much play do you get at the far end? Is there a big advantage over using rail dog and dropping onto the table when needed?Mafell is definitely a good saw. I made my own View attachment 103101View attachment 103102hinge set up for metabo rails it could definitely be adapted to mafell rails
No play every cut is spot on but haven’t done the 5 cut method yet tho. To be honest not sure that my mft top is 100 percent as I used a jig and router so couldn’t be sure that I was going to get perfect 90 cuts. I was intending to use a rail square like Peter Millard portable bench but can’t get one for metabo rails I use. Don’t think there’s any real advantages might be a little quicker to lift hinge up than completely remove rail with rail dogsThat looks good, how much play do you get at the far end? Is there a big advantage over using rail dog and dropping onto the table when needed?
Aidan
Hi, Just spotted this for the Metabo guide rails:No play every cut is spot on but haven’t done the 5 cut method yet tho. To be honest not sure that my mft top is 100 percent as I used a jig and router so couldn’t be sure that I was going to get perfect 90 cuts. I was intending to use a rail square like Peter Millard portable bench but can’t get one for metabo rails I use. Don’t think there’s any real advantages might be a little quicker to lift hinge up than completely remove rail with rail dogs
Either you didnt add a link or that's next level trolling@dave5898
Here’s the parts list and how I did it.
