Rail, Stretcher or Stile?
lastminute
26 Apr 2009
West Yorkshire
Talking to woody friends about woodwork terms, the above names are mentioned regularly.
None of us has served an apprenticeship in cabinet making, so can anyone explain which name should be used to indicate the part...'cross piece' and 'batten' is also a term used!!
Gerry
Rails run horizontally in doors.
Stiles run vertically in doors.
Stretchers are between two components to keep them apart. i.e. between chair legs.
~Nil carborundum illegitemi~
I am from a building background....so....a batten is something fixed on its own, like a piece of wood say screwed to the wall before hanging say cupboard onto the top edge of it. Or you can have a batten fixed onto a floor..so a single piece fixed in its own right. A cross peice I would say is any piece which crosses across something and could have a more specific name also used. A rail can be a runner beneath a table top or worktop, could be a face piece along the front edge of something ie below a window, or rail as in a fence running horizontaly. But could be more specific as in top, mid or lock, and bottom rail of a door, or say window shutter board. Stretcher I would use as in something which stretches across something as in say as 'batten' between two gables or haffits. Could also be a stretcher below a worktop. Stile is as in the 'rails' which are vertical and either side of a door make-up as in hinge stile or lock stile or closing stile, or.....confused? Stile is probaly the easiest one to define. In the joinery and building world a lot of names were used as in the body parts. Mouth, ear, birds mouth, cheek, sole plate, heel, toe, nose, foot, elbow, and there must be more around or were all used. More thought required here...nearly confuse myself now.
Berst wishes..this could be a long subject with interest. Spelling now corrected.
Rail: Something you hang on to.
Stretcher: Something you lie on.
Stile: Something you climb over, hopefully with a rail so you don't end up needing a stretcher. :lol: :lol:
Edit: What Deserter said. :wink:
For me as a furniture maker and how I was taught I tend to have
Door stiles Hinging, Locking or meeting these are all vertical components
Muntin the middle upright in a door construction or central division or slip in a drawer
Door Rails top, bottom or middle
Rails under a table top are apron rails or seat rails in chairs and the lower on rails on chairs or table are stretchers which add great strength to the construction. Top rails in chairs are crown or crest.
These are the words we use in Worcestershire (and City and Guilds when I was teaching it) but I am sure they will vary across the country
